Hello
I'd like to download this video, but neither TubeMaster nor URLSnooper see anything:
http://www.france4.fr/emissions/tvlab/videos/dynamo_-_le_pilote_02-06-2015_807535
I also watched the traffic with a web proxy (Privoxy), but hitting the URL returns a 403/Forbidden:
http://ftvodhdsecz-f.akamaihd.net/z/streaming-adaptatif_france-dom-tom/non-integrales/...632k,934k,.mp4
Does someone have an idea what else to try?
Thank you.
Results 1 to 25 of 25
hi
you can use youtube-dl but you need have ffmpeg too
exampleCode:youtube-dl --ffmpeg-location "PATH/OF/YOUR/FFMPEG/BIN" "http://www.france4.fr/emissions/tvlab/videos/dynamo_-_le_pilote_02-06-2015_807535"
Code:youtube-dl --ffmpeg-location "C:\ffmpeg-20150421-git-a924b83-win32-static\bin" "http://www.france4.fr/emissions/tvlab/videos/dynamo_-_le_pilote_02-06-2015_807535"
or directly
with ffmpeg
with livestreamerCode:ffmpeg -i "http://ftvodhdsecz-f.akamaihd.net/i/streaming-adaptatif_france-dom-tom/non-integrales/2015/S22/J5/TVLAB_DYNAMO_PILOTE_WEB-h264-web-,398k,632k,934k,.mp4.csmil/index_2_av.m3u8?null=" -c copy -bsf:a aac_adtstoasc DYNAMO-Le-pilote-NI_80457.mp4
Code:livestreamer "hls://http://ftvodhdsecz-f.akamaihd.net/i/streaming-adaptatif_france-dom-tom/non-integrales/2015/S22/J5/TVLAB_DYNAMO_PILOTE_WEB-h264-web-,398k,632k,934k,.mp4.csmil/index_2_av.m3u8?null=" best -o DYNAMO-Le-pilote-NI_80457.ts
Hello,
For some reason, when using ffmpeg to download the following video…
… which ends with this:Code:ffmpeg -i "https://cloudreplayfrancetv.akamaized.net/a2f88a60bd3e5/222609655_monde_TA.ism/ZXhwPTE1ODExMjk3OTZ+YWNsPSUyZmEyZjg4YTYwYmQzZTUlMmYyMjI2MDk2NTVfbW9uZGVfVEEuaXNtKn5obWFjPTU0NDRkYzQwMTA2Y2RlOTE3ZTVhYmIzOTQzMGQ1MWFhNTMyNWQ3MDg4MmRjNjFjMTQyNmU1OTkxMGRjYmU0ZjY=/222609655_monde_TA-video=768000.m3u8" -vcodec copy -acodec copy output.mp4
… I get no sound ("audio:0kB").Code:… ODExMjk3OTZ+YWNsPSUyZmEyZjg4YTYwYmQzZTUlMmYyMjI2MDk2NTVfbW9uZGVfVEEuaXNtKn5obWFjPTU0NDRkYzQwMTA2Y2RlOTE3ZTVhYmIzOTQzMGQ1 MWFhNTMyNWQ3MDg4MmRjNjFjMTQyNmU1OTkxMGRjYmU0ZjY=/222609655_monde_TA-video=768000-142.ts' for reading [hls @ 008109c0] Opening 'crypto+https://cloudreplayfrancetv.akamaized.net/a2f88a60bd3e5/222609655_monde_TA.ism/ZXhwPTE1 ODExMjk3OTZ+YWNsPSUyZmEyZjg4YTYwYmQzZTUlMmYyMjI2MDk2NTVfbW9uZGVfVEEuaXNtKn5obWFjPTU0NDRkYzQwMTA2Y2RlOTE3ZTVhYmIzOTQzMGQ1 MWFhNTMyNWQ3MDg4MmRjNjFjMTQyNmU1OTkxMGRjYmU0ZjY=/222609655_monde_TA-video=768000-143.ts' for reading frame=35700 fps=146 q=-1.0 Lsize= 342900kB time=00:23:47.96 bitrate=1967.2kbits/s speed=5.82x video:342717kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.053375%
To find the URL, I used Firefox's Video DownloadHelper and tried the line that says "mediaManifest".
Any idea why the audio is missing?
Thank you.Last edited by yetanotherlogin; 7th Feb 2020 at 16:48.
streamlink "https://cloudreplayfrancetv.akamaized.net/a2f88a60bd3e5/222609655_monde_TA.ism/ZXhwPTE1ODExMzUzNTB+YWNsPSUyZmEyZjg4YTYwYmQzZTUlMm YyMjI2MDk2NTVfbW9uZGVfVEEuaXNtKn5obWFjPTNmODUxMGEy ZDk4ODVmNDBmMmJlNmQ0ZDk1ZjRmZTdhNDRlZGY3Mzg4MjUzNW U0OWY0ZTYxMmU3YWE3ODU5YTY=/master.m3u8?hdnea=exp=1581114350~acl=%2fa2f88a60bd 3e5%2f222609655_monde_TA.ism*~hmac=d6b8ce9ba9cdceb 3db0be6f91f6a0a96eb537fa7144cf98eb5b49154296a694f" best -o video.ts
Try with "master.m3u8" not "768000.m3u8"
C:\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx>ff mpeg -i https://cloudreplayfran
cetv.akamaized.net/a2f88a60bd3e5/222609655_monde_TA.ism/ZXhwPTE1ODExMzUxNzh+YWNs
PSUyZmEyZjg4YTYwYmQzZTUlMmYyMjI2MDk2NTVfbW9uZGVfVE EuaXNtKn5obWFjPTJiZWY0NzVkYTI1
YzE4YWI5OThmMzRmMGVhMjc3MzlhMzIwN2VmMjk0NGFkZmY5YT czNDliM2E0ZTAzYTM3OTg=/master.
m3u8?hdnea=exp=1581114178~acl=%2fa2f88a60bd3e5%2f22260 9655_monde_TA.ism*~hmac=de
5228cc4eec16b8b3138cf3b63399ff6e8eba061fe431394805 eb983e752723
ffmpeg version 4.2 Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 9.1.1 (GCC) 20190807
Duration: 00:23:48.00, start: 10.000000, bitrate: 0 kb/s
Program 0
Metadata:
variant_bitrate : 190000
Stream #0:0(fr): Audio: aac (LC), 48000 Hz, stereo, fltp, 113 kb/s (default)
Metadata:
id3v2_priv.com.apple.streaming.transportStreamTime stamp: \x00\x00\x00\x00\
x00\x0d\xbb\xa0
comment : Audio Français
Stream #0:1: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yu
v420p, 384x216 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
Metadata:
Program 1
Metadata:
variant_bitrate : 320000
Metadata:
x00\x0d\xbb\xa0
Stream #0:2: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [
Metadata:
Program 2
Metadata:
variant_bitrate : 608000
Metadata:
x00\x0d\xbb\xa0
Stream #0:3: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 960x540 [
Metadata:
Program 3
Metadata:
variant_bitrate : 879000
Metadata:
x00\x0d\xbb\xa0
Stream #0:4: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1280x720
Metadata:
Output #0, mp4, to 'test.mp4':
Metadata:
encoder : Lavf58.29.100
Stream #0:0: Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1280x720 [SAR
1:1 DAR 16:9], q=2-31, 25 fps, 25 tbr, 90k tbn, 90k tbc
Metadata:
Stream #0:1(fr): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp
Metadata:
x00\x0d\xbb\xa0
Stream mapping:
Stream #0:4 -> #0:0 (copy)
Stream #0:0 -> #0:1 (copy)
Press [q] to stop, [?] for help
frame= 2498 fps=135 q=-1.0 size= 25344kB time=00:01:39.90 bitrate=2078.2kbits/
[hls @ 0000000000438f40] Opening 'crypto+https://cloudreplayfrancetv.akamaized.n
et/a2f88a60bd3e5/222609655_monde_TA.ism/ZXhwPTE1ODExMzUxNzh+YWNsPSUyZmEyZjg4YTYw
YmQzZTUlMmYyMjI2MDk2NTVfbW9uZGVfVEEuaXNtKn5obWFjPT JiZWY0NzVkYTI1YzE4YWI5OThmMzRm
MGVhMjc3MzlhMzIwN2VmMjk0NGFkZmY5YTczNDliM2E0ZTAzYT M3OTg=/222609655_monde_TA-audi
o_fre=64000-11.aac' for reading
frame= 2501 fps=124 q=-1.0 size= 25344kB time=00:01:40.01 bitrate=2076.0kbits/
MGVhMjc3MzlhMzIwN2VmMjk0NGFkZmY5YTczNDliM2E0ZTAzYT M3OTg=/222609655_monde_TA-vide
o=768000-12.ts' for reading
frame= 2748 fps=125 q=-1.0 size= 27648kB time=00:01:49.90 bitrate=2060.7kbits/
frame= 2749 fps=123 q=-1.0 Lsize= 27788kB time=00:01:49.93 bitrate=2070.7kbits
/s speed=4.92x
video:26434kB audio:1324kB subtitle:0kB other streams:0kB global headers:0kB mux
ing overhead: 0.105891%
Exiting normally, received signal 2. -
Thanks much!
1. In Firefox, install the Video DownloadHelper plug-in
2. Play the video
3. Use VDH to find the video's masterManifest
4. RunCode:ffmpeg -i "http://masterManifest.url" -o output.mp4
thank you all for the great input but i still can not make it work..
any of you are able to stream it with any tool like ffmpeg???
https://www.dmax.de/programme/undercover-billionaire/video/die-wette/DCB492260001100
none of these works...
https://dplaynordics-vod-05.akamaized.net/dplaydni/108737/0/hls/9492243004/playlist.m3...37caa448d699bf
https://dplaynordics-vod-05.akamaized.net/dplaydni/108737/0/hls/9492243004/exp=1589834..._hash=7fe60b32
https://dplaynordics-vod-05.akamaized.net/dplaydni/108737/0/hls/9492243004/exp=1589834..._hash=7fe60b32 -
wow! THANK YOU SO MUCH!
I fell blessed by your help and stupid because i have old linux distro and old versions and on manjaro it works beautiful
thank you again! @LZZA -
Hey, how did you find the video Link for downloading? I want to download the episodes from the following series:
https://dmax.de/sendungen/moonshiners/
I cant find any downloadable links? -
streamlink "https://dplaynordics-vod-06.akamaized.net/dplaydni/163911/0/hls/9810968004/playlist.m3u8?hdnts=st=1599832354~exp=1599918754~a cl=/dplaydni/163911/0/hls/9810968004/*~hmac=627cdcb2a00a17c53810bca57f570251b5a5332f6b0 24b451e4da82ca875e2d2" best -o video.ts
Thank you for your fast reply! Somehow youtube dl cant download the link you sent and also JDownloader dont find anything there?
I dont understand what you exactly mean? can you show me an example with a working link for downloading?
he means the download link expires so you need to get a new link you do that by going to developers console or f12 and go to network type in m3u8 copy link adres or try videodownloadhelper plugin goodluck
I cant find anything like that when searching for m3u8 and Videodownloadhelper only loads the video without the sound?
How can I download this video
By erhan_1498 in forum Newbie / General discussionsReplies: 0Last Post: 26th Jul 2014, 07:35 -
YOUTUBE - cannot download video RTMP(E) - Not VEVO video
By the Devil in forum Video Streaming DownloadingReplies: 2Last Post: 10th Dec 2013, 05:15 -
Capturing Local Copy of Akamai Stream
By HanFrolo in forum Video Streaming DownloadingReplies: 4Last Post: 23rd Nov 2013, 21:32 -
Port Scan Attack from Google. Inc and Akamai Technologies
By Bonie81 in forum Off topicReplies: 0Last Post: 6th Jan 2011, 13:17 -
How to download this video from video.xin.msn.com?
By Dark)AnGeL in forum Newbie / General discussionsReplies: 10Last Post: 9th Dec 2010, 19:06
